Hi all.
I am fitting a new kitchen that will have an eye level double oven. I will power it via a 6mm cooker cicuit. I have a cooker switch at worktop level that will run to a cooker outlet point in the cupboard (its a full height carcass that will house a 80mm double oven and two cupboards).
My question is: where is it recommended to put the cooker connection outlet point? Is it safe to go in the space that the oven will fit in? Or does it need to go the cupboard unit underneath (i was thinking to protect it to from heat).
I assume it is ok for it to directly behind the oven, about 1/3 way up vertically? I just want to check I am not missing anything important or obvious before I chase it in!
The spec for the oven we are thinking of oven buying says there is about 5cm space at the back when the oven us fitted. I would imagine they all leave enough space behind for a connection plate.....?
Thanks!
Chris
Thanks!
Chris
