My thermostat is currently located about 50 cm above and slightly to the left of a radiator.
I think this has effectively turned it into a readiator temperature monitoring device. To get the whole room to heat up to a comfortable level we often have to turn it up to 27 degrees and once that temp has been reached even if the room as a whole cools significantly the radiator stay warm so the thermostat doesn't trigger the boiler again.
I think this means I need to move the thermostat. Is this something I can do myself and where should the thermostat go.
The other side of the partition wall that the thermostat is currently on is a cupboard. Can the thermostat be in a cupboard?
