- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The system has two thermostats, one for day and one for night, during the day the thermostat from experiment needs to be close to the radiator and high to compensate for being close to the radiator.
However at night the room used has the radiator under the bay window, putting the thermostat near the radiator means it is sheltered by the wardrobe or on an outside wall, neither really a good location.
Either too hot or too cold will mean my mother does not sleep the whole night so we will get interrupted sleep so keeping that room spot on is important. Most likely seems to be the wall between living room and bedroom, which is not very close to the receiving station so uncertain if it will work there anyway.
It was a wired thermostat, but about 6 years ago my dad had the whole central heating changed and they ripped out the thermostat cables and went to a radio type. This was in the hall, and for some reason no TRV was fitted in the kitchen, wet room or hall.
The control was a total failure it depended on wind direction, all attempts to regulate the TRV failed, and the living room would one day be sitting at 17°C the next at 27°C so I fitted a second radio controlled thermostat since in real terms there are only two rooms to worry about, the living room and bed room. So the time was set for the heating to go off with the living room thermostat at the same time as the time brought on the heat with the hall thermostat.
It had some problems to start with, I placed the thermostat well away from the radiator and the hysteresis was silly, putting it a lot closer to the radiator did cure that problem.
The bed room did have problems, and I realised the thermostat needed moving to the bed room, when the house was re-wired the thermostat was taken down and light switches replaced it. So now it's a case of drilling two holes and fitting in bed room. Simple I thought.
However radiator under a bay window so thermostat can't go there, the 90° wall on one side is an outside wall and so not really the place for a thermostat fixed to a wall, and the other 90° wall has a wardrobe, then a TV so first section no free air movement and second section has heat from TV. Which leaves just the wall opposite to where the radiator is fitted.
But being so far from the radiator is also a problem with hysteresis. So other than having a cord and hanging off the light fitting I really do not know where to put it. One thing very clear is a hall with massive drafts is not the place for a thermostat.
Ideas please.
Ideas please.
