Where would you put the handles and why?
11 Apr 2010
Cambridgeshire
Hi. Title says it all really. I've filled in the handle locations that I'm sure of/are obvious....but what about the corner cupboards and the other base drawerline unit - which sides of the cupboard doors would you go for and why? I can't decide what'll be best practically and/or look the best
Opinions please :p
Door under the sink: Hinge on the right, handle on the left
Door to right of cooker: Hinge on the left, handle on the right
(So that when you open door on cupboard next to cooker its handle can't damage surface of door on cupboard under sink)
Door to left of cooker: Hinge on the right, handle on the left
(To match look of wall cupboard immediately above it)
Not sure about the cupboard above the cooker. Hinged along it's top edge with horizontal handle at bottom edge? Or is that an extractor housing?
Do the two tall thin cupboards on the far left pull out towards you, hence the horizontal handles? If not, then I'd hinge on the left and put vertical handles on the right unless that would cause the handles to mark the wall.
But then again, I could be wrong :LOL:
