Which Aerial CoAx Connectors? And a question RE couplers
8 Sep 2010
South West Wales
Hi again
Having decided from my previous post to go with Webro WF100 (100m for £40 on Amazon), now I'm trying to find out what connector to use . I just need a CoAx to connect to the TV. Any recommendations please? At the aerial, the cable connects via screw terminals so nothing needed there.
Also, as I'm doing the aerial cable upgrade, and because I will be doing work in and redecorating the living room, I was thinking to put in a second aerial point in the room "just in case" for future reference. The aerial is in the loft. The cable runs the length of the loft, around 10m. Then it drops through the bedroom and into the living room, so a drop of around 6m. A few more metres for bends, to each the TV, etc. I'm thinking there are two options....
1. Run two completely separate cables to their chosen points in the living room. Leave the one not in use disconnected at the aerial but there if needed.
2. Run a single cable from the aerial to an easily accessible point, either in the loft or the bedroom. Put a connector on there. Then use a coupler to join one of the two cables from the living room as required. This would result in less overall cable. But how much signal loss is there when using couplers?
Any thoughts most appreciated, including other ideas :)
Cheers
Couplers contribute at most about 0.5dB signal loss, but often it's 0.2dB or lower. In the grand scheme of things this is an insignificant amount where the aerial system has at least 15-20dB of headroom to play with.
To put the loss in perspective, WF100 has 0.15 loss per metre (1.5dB/10m), and a decent two-way splitter results in a signal loss of 3.5~4.0dB for the outputs. Your plan to do a cable swap connection won't cause any issues at all. I might even be tempted to install a simple 1:2 splitter at some point close to the living room so that both outputs are live.
If this or any other reply was helpful to you, then please do the decent thing and click the T-H-A-N-K-S button. It appears when you hover the mouse pointer near the Quote Multi-quote buttons. This is the proper way to show your thanks for the time and help someone gave you.
As I have told you both on here and the other forum:
Crimp or compression F connectors with Belling Lee adapters where required.
The other point. Run a single cable to an easily accessible point and fit a 2 way splitter there. Run one output to you TV and the other output to the second point.
