Which blocks for garage foundation?
6 Mar 2014
Birmingham
I have laid the footings for a garage and am going to start laying blocks to come up to the floor level/damp course. Only thing is I am not sure which are the right type of blocks to be using?
As they are going to support the rest of the garage walls, should I use high strength concrete blocks such as 7.2N or will I be fine using standard 3.6N blocks? Also are all concrete blocks suitable for use below the damp course/below ground level?
My garage will have an eaves height of 2.5m and be single skin using 440x215x100 blocks.
Thank you in advance for your help.
Use 7n dense concrete blocks below ground/DPC.
Use class B engineering bricks where masonry is showing above ground and below DPC.
yep use 7n blocks below ground level then you can pick up the rest with class b or just run stright up with the block work from damp if you wanted
