Hi Guys,
Got a cheap blow torch at the moment, gas is running out.
I'm planning on fitting a new bathroom etc later this year. I'm thinking I'll be better off buying a better torch as I know I will be soldering joints under floor boards.
I current torch is fine until you tilt it close to 90 degrees then it flames out. Obviously I'm not a pro, so don't want to shell out loads of money on a torch that I'm probably only going to use a few times a year.
Can anyone recommend a half decent torch for soldering 15 /22mm pipe under the floor?
Cheers
Adam
Cheers
Adam
