Hi i had to move out of my apartment and move back with my parents to take care of them. i rented out the apartment and the boiler (an Ideal Istor HE260) has packed up. i had a British Gas Home care insurance plan and when the engineer came he closed the boiler down as he said there was a small leak from the heat exchanger. He said that's why the ignition electrode was corroding and then not sparking. Can i trust British Gas Engineers? Secondly if i replace the boiler what type shall i go with? I am torn between a straight combi, combi with a storage tank (like a valliant 938), or a regular boiler with a small unvented cylinder. I am concerned that if any future boiler breaks down then the tenant has no backup immersion. How long do unvented cylinders take to heat up? The apartment is small at only 650sq ft but has tow bathrooms. i want to be able to have good pressure when using two hot water sources if possible. I assume the incoming water pressure is good but i will get the plumbers to check when they quote. The trouble i find is that all plumbers say different things!
