Which boiler is best ?
30 Nov 2017
So im due a new boiler as my current boiler glowworm 24cxi decides when to work keeps coming up with different faults looking to upgrade to either BAXI or WORCESTER its for a 3 bedroom semi detached house with 9 radiators
neither.either.baxi.bosch.vitodens.vaillant.....plus many more...All replies in one message
Well im asking which out of the 2 is the better quality and good for the money
I always fit baxi.They are not complicated to work on and quite reliable.I find Wb over engineered crap and harder to work on..Others will tell you quite different.Like buying anything.Do some research.Depends on your budget..Each engineer has a favourite brand.Personally I do not rate glow worm highly either
Best thing about WB is their marketing structure, Baxi/potterton are decent and easy to work on but if your looking for a cut above the rest look into an Intergas.
As above, go for Intergas - 10 year warranty on the ECO RF and built to last with all metal internals and only 4 moving parts. Out of Worcester and Baxi I'd say Baxi, but the Intergas beats both of them
It’s the aftercare if the boiler fails, I can only go off feedback and experience baxi/Ideal usually 48hrs, Vaillant/glowworm 48/72hrs Worcester 24hrs not sure on intergas as for ferroli hmmm.
What ever boiler you have will need a call out from manufacture and certain manufacturers engineers don’t help themselves, but Worcester will change anything on the boiler without question comparing to others that will have call out charges/ etc.
As I say it’s only feedback and experience I’ve had so no one bites my head off
Worcester 24 hours my foot, took them 2.5 days to attend to a 3 month old boiler with a dead PCB when I called them last year. Had Intergas out once last year as well, turned up in 3 hours
Hey I’m only going on feedback/experience in my area. Just giving my opinion, not slating any manufacturers at all. I’m sure intergas are very good and that’s what we as engineers expect
Read more: https://www.diynot.com/diy/threads/which-boiler-is-best.498270/#ixzz57yTcI4iY
Boolliacks.
New boiler fitted 6 weeks later thermistor blew out. Factory fitted Worcester are trying to wriggle out of it. Fellow rgi being screwed over.
All manufacturers will try and wriggle if they can.
As for the OP. Please and thank you not compulsory words , but they make us unpaid helpers all fuzzy and warm inside.. (y)
