Hello everyone,
I'm wanting to put up a 32" TV wall mount in my apartment, it's a tilting bracket type, which came with 10mm x 50mm rawlplugs and associated bolts to fix the bracket to the wall. the TV weighs around 15kg.
The problem is, the wall I want to fix it to is very thick plasterboard; the total thickness of the wall before the cavity is around 40mm, and then the cavity itself is pretty large, I'd say at least another 50mm before you get to the insulation on the outer wall - the apartment is on the corner of the apartment block. All the cavity wall fixings I can find have a maximum thickness of around half that, 24mm. The wall is too powdery and weak in my opinion for the standard rawlplugs to be sufficient. Should I go for some of those spring wall anchors and just get long enough bolts to fit all the way through, again the bolts that come in those packages seem to only fit around 24mm. Plus I don't like how thin those are compared to the 10mm bolts that came with the kit. Or does anyone know of a manufacturer of expanding bolts that would work on a 40mm cavity wall?
Thanks,
Gareth
Thanks,
Gareth
