ok which boiler Vaillant 838 or Vaillant 938, is best or most suited for the following property with following needs
15 double sized radiators. maybe add 1 more in the future.
6 bedroom upstairs
one main bathroom
one ensuite
2 large living rooms down stairs.
2 kitchens
one wc. (maybe add a shower to this, although probably won't as it not really needed)
currently we have in both showers both the electric and combi option for shower. this is because if the electric shower breaks we can use the combi for showering. and if the boiler breaks we can use the electric shower etc.. both are a back up for each other.
I prefer to shower with the combi in the ensuite. the main one is mainly on electric shower...
the reason i ask this question is because our stop tap allows about 10 litres per min . 10L/M.
so the 838 and and 938 give a flow rate of 15.9 l /m however the 838 can only give out what it gets in. so if it only gets 10l/m from the stop tap, its flow rate will be that. i.e 10l/m.. therefore a waste of 5.9L/m .
however i called vaillant today and they said the 938 has two cylinder tanks in it which store water providing instant hot water where as the 838 has water on demand i.e it heats it up as you go along. therefore the 938 can give you a flow rate of 15.9l/m although it may only gets 10l/m. this is because it stores the hot water and uses this as you use the shower...
i hope I'm making sense.
the total kw of all the double radiators at t50 is about 23.5 kw and at t60 is 30kw. so 38kw boiler should work giving 100,000 btus and 30kw of energy.
when i shower in the ensuite the shower is great. however if someone in either kitchen opens the tap or even the wc or even in the bathroom. thats a potential of 4 taps diverting the flow of hot water from my shower. there is an obvious and drastic drop of hot water pressure, depending on how many taps are opened whilst i shower... the problem may only be for a few mins but its there..
if i am going to pay £2500-3000 for a new boiler fitted. i might has do some homework to ask which is the best boiler and which is most efficient etc...
so once again.
1) which is the best boiler on the above info..
2) and my main concern is the efficiency will the 938 cost me more to run over the course of eg 10 years... (as i will get 10 year guarantee with all the bits that i need to get this amount of cover) annual service.. etc..
average 10/20 showers per week on the combi boiler.
just two questions.
thanks
6 bedroom upstairs
one main bathroom
one ensuite
2 kitchens
so once again.
just two questions.
thanks
