We're building a single storey, 5m x 4m flat-roofed extension to our kitchen (rather than a typical bolt-on conservatory) as we want to be able to use it all year round. It has floor to ceiling glazing on three elevations to make the most of the central garden setting. The otherwise well-insulated ceiling has a flat skylight. I haven't got the U values for the glazing to hand but it's noticeably chunky compared to what we already have. The floor is beam and block to be finished with 100 cellotex and a 50mm screed. Wet or dry UFH are the options we're considering.
When it comes to specifying the heating Ideally we would go with underfloor as there is only one masonry wall for a radiator (provided by the house it's built against) and what remains of this after the existing french window opening is earmarked for furniture.
A lot of the discussion steering people away from electric UFH is in relation to conservatories due to their enormous heat losses. If we had masonry walls with cavity insulation I don't think there'd be much objection to electric. However, we're a little bit unusual in having fully glazed external elevations which I've not seen in discussions regarding heating.
Electric would be extremely handy as we'd otherwise have to destroy a tiled kitchen floor to get to the existing CH pipes. Another awkward issue would be where to locate the pump/valve gear for a wet system. On the other hand there's an unused 13A Fused outlet on the back of the outside wall. Lastly, I can see gas prices closing-up on electric in the not-too-distant future as the UK energy mix changes to lower carbon sources. Any thoughts would be greatly appreciated.
