suppose I have two pieces of 2x2 that I want to join (like a butt join on the 2x2 end) in a manner that will resist an applied tension/compression along the full length of the 2x2. There's a bit of shear, but mainly tension/compression..
Lacking a finger jointer or any similar tool, i'm limited to what I can do with a table saw, sliding compound mitre saw and circular saw
Should I:
Cut a 2x1x12 cuboid out of the end of each stud, meaning the two can overlap for 12 inches and a sort of square dog legged joint will appear on the side of the finished stud
or
Cut a wedge shape off the end of each stud, that starts out 2x2, but goes to nothing over the course of 12 inches, meaning that when overlapped a diagonal joint line will appear running across the stud
I'll be glueing and screwing each joint (partly threaded screws )
The wedge shaped one seems easier to do (I can make a set square of a fixed angle using some ply with a batten screwed to it at an angle), put it on the stud, run a circular saw along the angled ply
The square dog legged joint is harder, as i need to stick the end of the joint into the table saw for 12 inches (on a 4.8m stud) then cross cut it to half the depth.. Bit messy too because I have to cut deeper than 12 inches due to the blade being circular, before I crosscut
If the two joints are equal strength then all things considered i'll probably to the wedge shape, especially seeing as I'm using this technique to joint a 4.8m 2x2 and a 2.4m 2x2, and I'll then glue and screw bond this jointed piece, to another piece the sdame (but flipped over so the other joint is about 2.4m away from the first one)
If none of this makes sense, let me know and I'll post up a pic..
Should I:
or
