Which mid-hi end Mitre saw
17 Dec 2008
Nottingham
The DW718 you link to is a 12in saw. On paper you might think they're better, but in actual use the 10in DW717 is noticeably more accurate, not to mention easier to move around (smaller/lighter)
The KGS216 is an 8in saw, and whilst it is unusual amongst 8inchers in being a double bevel saw, it ain't a 10in saw. For that look at the KGS254.
You know, trying to compare apples and oranges on price is a bit of a non-starter. Why not try to define your requirements THEN look at saws which match that specification AND come within your budget?
I've got a Makita LS1013 and I'd highly recommend one.
I'll second that. Good saw, if a bit ong in the tooth (and a favourite of plant hire firms). It's being replaced by the LS1016 - more expensive, and the LS1018 - lower cost, Chinese build. Not sure which I'd go for if push came to shove.
Ok thanks so far guys,
I have a Macallister sliding mitre saw at hte moment. Had it about 6 years, changed the blade to give it a new lease of life. It custs up to 305mm at 90°. I've used it for everything including laminate floor boards (which is why i ended up changin the blade).
It only cost £!45, it's certainly paid for itself, but there are some angles that are aren't 'true', so its not terribly accurate now. It aint double bevel and that's a right ball-ache when trying to cut shaped architrave/skirting/dado's etc.
So, 10" would be fine, needs to be double-bevelled and after plenty of reading it seems to get a saw that's accurate on both bevels then you need to pay for a quality brand like Dewalt, Bosch, Makita or Metabo.
I have £500 to spend, would like to get the right saw for less if possible, but i may only have this money once so don't want to regret going cheaper now, knowing that i won't have the money to get a better one in a couple of years time if what i've bought aint good enough, if that makes sense.
