Which perforated pipe for drainage field?
2 Nov 2006
Lincolnshire
The drainage field needs replacing on my septic tank,it wasn't correctly sized or installed when first commissioned-there are many of these systems localy,and they all seem to use the flexible land drain which is specifically mentioned as being unsuitable in Klargester's literature-what is the position,the BCO doesn't see to mind using land drain-are there any dsadvantages i should be aware of?
I think you need to contact klargester for the low-down.
It might just be cause they want you to use their own specified products. Like when printer manufacturers recommend that you only use their own 'genuine' ink. (in other words, BS)
I've used the 4" before with a fleece type wrap covering it but the silt fines here soon clogged that up. To be honest the best way is to use the un-wrapped pipe buried in straw i've never had a problem when using it.
thanks deluks and ajs-bit more research needed-must say i've not heard of the straw thing-my understanding is 300mm of 20-50 stone below pipe and 50mm above then geotextile then normal backfill.
the internal silt will lay in the concertina grooves :idea: if you use slotted u/ground plastic, it won`t
thanks Nige-so i guess the silt sits in the concertina bits,this then blocks the drainage holes,I was thinking about getting some plain pipe and drilling a load of holes as the proper perforated pipe is v.expensive.
Use a grinder or recip saw and cut slits along it's length.
I'd look for a few suppliers online, IIRC the perforated 110mm pipe isnt vastly more expensive. I'd be happy to pay the slight extra than be drilling a few hundred holes... ;)
looks like the perforated pipe is twice the price of the plain-say an extra £15 every 6 metres-and i need quite a bit of pipe,so looks like angle grinder here i come!Thanks for the advice.
