Okay, it was going to happen. Burst pipes in loft. Pipes were lagged with the usual grey 20mm wall bungee, but they froze just the same.
The pipe runs are straight, very long and go over the joists (so they don't benefit from the rest of the loft insulation. It's as if they are outside pipes. It's a very big house, with an awful lot of pipework, so it's not all kept moving either.
I would guess that the loft may have gone as low as -20C. The loft is like a deep freeze even at the best of times, so this will certainly happen again (it's now pretty clear that it came within an ace of happening last year, too).
So, what insulation to put on once the pipes are repaired? I've checked the regs for frost protection and the pipe situation is graded as 'extreme'.
Regular Climaflex may simply not be enough, even if it's physically possible to fit a greatly increased thickness (due to pipes being close together).
The loft is huge (it's like an aircraft hanger), so there's no possibility of tube heaters or anything like that, either.
Any recommendations?
