- Joined
- 7 Sep 2009
- Messages
- 11
- Reaction score
- 0
- Country
Hi there,
We've just moved house and we've had three plumbers round to give us quotes for new radiators, the house is ten years old and some of the radiators are rusted at the corners and dripping. Do they normally do this after ten years or so?
Apparantly there is an issue with having a wall thermostat next to a radiator thermostat.
We moved in last week and haven't had the heating on yet, but our hall is quite big and has three radiators in it, two are quite close to the wall mounted thermostat and one is 6 ft away. All radiators in the hall have thermostatic valves on them and the three plumbers are giving me different advice.
1st plumber says to turn the closest radiator down to minimum on the thermostatic valve.
2nd plumber says all radiators in the hall should have normal valves on them.
3rd plumbers says only the closest radiator to the wall thermostat needs its thermostatic valve removing.
Which is right? And why won't it work as it is?
