Which Saw?
27 Nov 2008
Armagh
I need a saw that would be used for cutting long lengths of wood for door frames and for fascia boards.
Would a circular saw be best or what other types would you recommend?
Sliding mitre saw.
Does that job & will do plenty more later on.
Which one depends on how much you want to spend.
If you dont want to spend a l then there is always these. :D
A Jack handsaw will do.
But it depends on if you are doing 5 or 500 cuts.
A circular saw is not the best type for cutting timber narrower than the saw's base bate
Here you are, a man that knows wood well.
Whats a "base bate" woody? :D
And why is a circular saw not good for what you have described?
I'm curious to know & learn.
Whats a "base bate"
I have not got a clue ..... neither do I know how anyone can type a b instead of a pl :rolleyes:
Try following a line and doing a square cut with a circular saw when you cant see the timber beneath the bate, and can't keep the saw steady on a narrow bit of timber
="^woody^";p="1273884"Try following a line and doing a square cut with a circular saw when you cant see the timber beneath the bate, and can't keep the saw steady on a narrow bit of timber
Easy peasy.
You supplement the narrow bit with a wider slave bit to stabilize.
To keep the saw steady you cramp an aluminium straight edge (fence) for the saw base plate to follow.
Aaaanyhoo, you do not use hand held circ' saws for their accuracy, merely for their portability.
And by the time you've messed about clamping guides or using additional timber ....... you could have cut through it with the hand saw
i know it's been a week or so ,but Haveagoer said"I need a saw that would be used for cutting long lengths of wood for door frames and for fascia boards".the question is will you be using it to rip or cross cut,if you want to rip cut the timber(along the grain) i would suggest buying a cheap table saw.ok,i know you will need to practice your frisbee throwing technique with the blade and buy a decent mid-range multi-purpose one,but it's still worth it if you have a lot of ripping to do,not only that,you then have a saw for all seasons,or you could try a flip over saw,though i've never used one so can't vouch for how good they are.
Easy peasy.
What's the difference between cramping and clamping ? I've always wondered :?:
I think I might need to get out a bit more.
What's the difference between cramping and clamping ? I've always wondered.
Clamp, and the verbal participle clamping, are the terms used in North America; cramp and cramping are the traditional terms used in the UK. However, American usage tends to drive out UK usage and I suspect that is happening with these words.
So, no need for you to get out more at all.
Thanks for that, however, I suspect you may need to get out a bit more :LOL:
So..... you car is cramped in this country :?:
