With regard to my project re insulating my park home can i use wood screws to penetrate the softwood timber battens and the thin aluminium skin it has to go through as well?
depending how thick the frame is use dry wall (plasrerboard) screws they have a better thread for screwing through metal. if the frame is to thick to screw straight through drill a 2.5mm pilot hole first
