Hi all,
I'm new here and also new to DIY.. I'm just about to get started on boarding out my loft but I'm not sure what size and type of screws would be best.. the boarding is purely for light storage space.
My joists are 1.5" x 4.5" and I'm laying 34mm x 34mm battens across the top. The boarding is standard 18mm chip board.
I assume standard wood screws will suffice but what length and type should I be using?
I thought perhaps the best way would be to first screw down the battens into the joists, and then screw the boarding into the battens, that way I can avoid using massively long screws, and it will be easier to avoid screwing into cables or pipes. Does that sound right?
(Additional Note: I should also perhaps be careful about using too many screws and/or going too deep into the joists, to avoid weakening them, as I have no additional support on the joists. A structural engineer has assured me it will be fine without, since my storage weight is fairly low..and he's given me a 20kg per m2 limit.)
