Which Shower Pump
29 Nov 2013
Gloucestershire
Apologies if this has been covered many times before.
I'm planning on getting a Stuart Turner Monsoon 2bar positive head pump to power my shower. There is fairly good hot and cold gravity fed supply pressure to the pump.
However, before I go ahead I'd just like to ask for opinions on this pump make and/or model, and if there are any better pumps available.
Stuart turner are generally accepted to be the best. I have fitted a few of these and have the 4 bar monsoon at the moment. the pressure that you need depends on a few factors. How many showers have you got? do you have a high volume rainflow head? do you have body jets etc...
regards
BS
Stuart Turner it is then and probably from Screwfix. I only need it to supply one shower with a fairly standard shower head and no body jets, so i imagine the 2 bar model should be good enough. Thanks.
