Which shower?
13 Jan 2016
Never used the Grohe but I had a Mira Platinum dual outlet in my last house and it was excellent - with both heads turned on it overwhelmed the capacity of the high-flow waste outlet
Thanks muggles - good to know it can achieve the Flow rate. Would you have it again? Any other pros & cons to it?
Main con is that it's expensive! Personally not a fan of wireless control, I'd rather have it wired for reliability, but that's a minor issue really. It lost connection a couple of times in the 5 years I was in that house, necessitating going into the loft to reset it, but 2 occurrences in 5 years I suppose isn't too bad
Thanks.
does anyone know if either of these would be suitable with a 400mm shower head?
Pressurised system with 2.5 bar. Thanks
If the head is correctly selected it'll be fine. Look at the manufacturer's tech specs to match it correctly to the shower - not all heads are created equally
