Hi there, I think I know this already but what's the best steel for wood turning tools, and if you can, could you order them.
Special Grade Alloy Steel
Carbon Steel
HSS
Tom
when I've wanted a certain grade of steel bar (round) I've gone to local engineering shops
and brought off cuts but flat bar is harder to procure of the right carbon grade
(they don't make many grades now) often involved recycling something.
can't besure but I think you want carbon content 0.7%
I have found a convenient material is silver steel. I've made quite a few tools for metal turning.It's usually available in 13" lengths.
Why 13"? I havent got a clue!
I've used diameters from about 3mm to 1 1/2" at various times for various tools.
As a general rule, carbon steel tools can be made, shaped and heat treated relatively easily in a home workshop, and honed to a finer edge than HSS, but when in use HSS will hold it's edge better than carbon steel.
For flat stock, how about annealing old scrap files ?
