I have an ACV 300SLME thermal store linked an Worcester oil boiler. The oil side has pumped flow and return.
http://www.acv-uk.com/slme.htm
The radiator circuit is pumped from the primary water in the ACV outer water jacket, the same water as goes through the oil boiler. (The oil boiler is NOT connected to the coil in the ACV tank).
The thermostat on the top of the ACV tank is in the secondary “potable” water and triggers the oil stove to come on, to heat the DHW, when the secondary water temp drops below the thermostat setting on the ACV.
The radiators have a room stat and when the room stat calls for heat it turns on just the radiator pump…… however the oil boiler will not fire up because the secondary water is “up to temp” as far as the ACV tank thermostat is concerned.
Only after the temp of the primary water drops, as it goes round the rads, pulling down the temp of the secondary water, does the oil boiler kick back in again.
What it means is the secondary water temperature is cycling as the radiators call for heat.
Ideally I would have liked to see the secondary water temp stay as constant as possible and when the room stat calls for heat, the oil boiler fires immediately and the primary hot water it produces goes straight round the radiators.
Do you have any recommendations as to the type of central heating timeclock that cold achieve this, or is this setup how it is normally done?
I have heard about “2 channel” and “single channel” programmers, are either these capable of controlling this way?
(apologies if this should be in the "electrics" forum, could the moderator move it if needs be please.).
