This amateur finds a Stanley knife with the minimum amout of blade protruding ideal - length of the blade is just right.securespark said:A sharp knife run down the centre of T & E, then nick off the sheath at the bottom.
Do they work?JDLDIY said:Yeah the stanley knife technique is mine too, just wondered if anyone used one of the more proprietary tools available to do the job. The one I've seen has black self adjusting jaws and red handles.
JD
clarke24 said:screwfix sell an automatic wire stripper that will split the t&e neatly then the excess pulls off can then be used on the inner cores aswell its great you'll only need this and a screwdriver when terminating and its so quick!!!
Not sure really, a mate had one which worked well for a fairly short while but then started to be less reliable.....Do they work
Is it one of these:clarke24 said:screwfix sell an automatic wire stripper that will split the t&e neatly then the excess pulls off can then be used on the inner cores aswell its great you'll only need this and a screwdriver when terminating and its so quick!!!
ban-all-sheds said:I can highly recommend them. Doesn't do the sheath, but for stripping cores it's superb.
