Hello
I've just had a wall skimmed in a bedroom. We'd taken all the old plaster off surrounding the window as it was blown really badly so the plasterer put drywall onto the brick work and then skimmed over it.
Now I want to fix a curtain pole above the window but I'm wondering if I should use wall plugs for bricks or or wall plugs for drywall?
The window itself is 107cm wide, so the curtain pole will be around 130cm long in total.
Thank you.
Thank you.
