Just finished decorating passage way and landing and want to put a new two switch light switch in to work both the passage light and upstairs landing light as the one up looks a bit grubby.
The thing is at the moment the left hand switch as you look at it works the upstairs landing light which i can turn on and off from both downstairs and upstairs and the right hand switch works the passage light, both work perfectly fine but i want to change it so left hand switch works passage light and right hand switch works upstairs landing light.
At the moment the wiring is as follows:-
Left hand switch as you look at it has common at bottom with two red wires attached and at the top a yellow wire into L1 and a blue wire into L2.
Right hand switch as you look at it has single red wire into the other common at the bottom of the switch and nothing in L1 and a single yellow wire in L2 at the top of the switch.
Which wires do i need to change over so passage uses left hand side switch and upstairs landing light uses right hand side switch.
Cheers.
Cheers.
