R
roberta1000
My Whirlpool ADG7560/1 dishwasher will not switch on using the on/off button on the top of the door. If I try it many times, occasionally it WILL switch on but then goes off again either as soon as the door is closed or else a few seconds later (all lights go out). If I get it to switch on I can select the different programs as normal but it always switches off again either on the first bump or a few seconds after closing the door.
Does it sound as though the off/on switch has failed or is there some other fault likely? If it might be the switch how do I open the door up to get access to it to replace? Thanks.
