Whirlpool ADG957 Beeping, 30min flashing, 60 degree solid
11 Nov 2009
Dorset
I see a number of similiar problems posted - but my symptoms are slightly different so would appreciate some help.
My 7 year old ADG957 dishwasher stopped mid cycle the other day and started to continously beep.
Now we've emptied it out & drained all the water out.
If I turn it on now (after clearing the fault) It makes a continuous beep, the pump runs and does drain liquid from the machine - but thats it.
When I open the door the 30 min/40degree light is flashing and the 65 degree (3 plates) lights is on solidly.
I've removed the drain pump, cleaned it - nothing obviously wrong here.
I've checked the heater - 25 ohms - checked it via the cable from the control module - all good there.
I dismantled the door and checked every wire for a visual break - nothing obvious.
I'm now lost as to what to do next. If it is a control module - then it is not worth it - but if it is the NTC then it might be.
Expert guidance gratefully received!
Cheers,
Andy
any water in the base this will stop it filling tip mc back see if water comes out . Whirlpool Dishwasher Fault Codes
Code Start Light Flash Sequence If Applicable Description
F1 1 x Flash 1 Second pause 1 x flash NTC Failure
F2 2 x Flashes 1 Second pause 2 x flashes Water Leakage
F3 3 x Flashes 1 Second pause 3 x flashes Failure in
Heating System
F4 4 x Flashes 1 Second Pause 4 x Flashes DrainingFailure
F5 5 x Flashes 1 Second pause 5 x Flashes Rotor Blocked
F6 6 x Flashes 1 Second pause 6 x Flashes Water Tap
Closed
F7 7 x Flashes 1 Second pause 7 x Flashes Flow Meter
Failure
F8 8 x Flashes 1 Second pause 8 x Flashes Water Level
Failure
F9 9 x Flashes 1 Second Pause 9 x Flashes Continuous
Water Inlet
F0 10 x Flashes 1 Second pause 10 x Flashes Sensor Failure
(Only displayed
in act.test
program)
FA 11x Flashes 1 x Second pause 11x Flashes Optical Water
Indicator
FB 12 x Flashes 1 x Second pause 12 x Flashes Motorised
Diverter Valve
FC 13 x Flashes 1 Second pause 13xFlashes Water Hardness
Sensor
Definitely no water in the base - tipped the machine back when I removed the pump to check it.
I saw these error codes - but as you can see my symptoms don't really match up with any one error code - which worries me a bit!
Any further thoughts?
Andy
