Whirlpool ADP4504 Stop Start on Drain and fill
8 Mar 2009
Mid Glamorgan
Hi, a few weeks a go my Whirlpool ADP4504 developed a problem where when i press the start button to start to cycle it would start to drain and then stop. It would start and then stop continuously until it finished draining. When the fill cycle starts it would do the same, start and stop. The wash cycle is fine and the dishwasher washes ok. Its just the drain and fill cycle that seems to stop start.
Heres what i've done so far. I've removed the switch at the bottom of the water inlet column and put it back. I have also checked the water inlet filter and this seems ok. I have removed the pressure switch and cleaned the mesh and contacts and put this back. But now after doing this is just sticks on the drain cycle. It doesn't get passed this stage now. Do you think this is the symptoms of a faulty pressure switch? I would appreciate any feedback on this. Many thanks
I have since replaced the pressure swicth and it does exactly the same so im at a loss to what is causing this. It doesn't seem anyone know what the issue is so i'll probably scrap and buy a new one.
Not knowing the exact layout of this appliance but you may have a build up of crud in the inlet resevoir or where the pressure switch is (quite often rubbish builds up and needs cleaning out) this prevents the pressure switch sensing water in the machine so it times out or the overflow on the tank can operate due to water not entering the sump properly, either can cause the pump to drain out.
