Whirlpool AWM336
14 Dec 2005
West Lothian
Hi people
new to this site and as you guessed looking for some advice.
The Whirlpool AWN336 washine machine doesn't spin properly. i'm no expert but there is 2 spin speeds 600rpm and 1200rpm I would guess it only spinning at 600rpm as the cloths are quite wet when it finishes.
So I am thinking the button which seems ok as it stays in when press or the controller behind it or would worn bushes have this affect.
The pump is clear it does spin is there anything else that it could be any advice welcome.
Eric
Hi it could be a fault on the circuit board had a washer doing similar thing and it was a circuit board fault
Had a look at the motor and the was a wire lose the last wire could that cause it not to spin at full?
