Whirlpool awm5145-2 front loading washing machine probs....
15 Feb 2010
London
When you put on the cycle and press on the machine switch, the dial just turns a little bit then does nothing. The only thing that it will do is make a little whirrring noise, also if u set it on the seperate drain cycle it seems to work ok and then u can open the door. Do I need a new machine? Or call Whirlpool engineers out? Could it be a fuse prob as in last 2 weeks every time I turn my oven on the tripp switch goes, would that affect my washing machine?
any help would be kindly appreciated!!!
