I've done some reading about and some poking about the appliance but I'm still a little lost so any help appreciated with the following situation.
I did a few High temperature washes last week and returned to do a normal wash on Fri to find that the machine wouldn't start the cycle properly.
When I select a cycle on 1000 rpm spin the fill solenoid is operated intermittently in bursts of a half second or so and then ceases, there is no further movement.
I can manually advance the cycles and I hear what I believe to be the heating element working OK and it drains but there is no movement from the drum and it doesn't look like power is supplied to the motor. The brushes look fine, I've looked at the control module and motor which advances and both appear healthy (the motor runs OK and there is no visible damage inside the control module with all contacts engaging as you rotate it by hand).
Oddly enough I pushed the half speed spin button in last night and this resulted in the water fill solenoid opening properly and the machine appeared to advance through its cycle though it still refused to spin.
Unfortunately washing machines / washer dryers are not my strong poing and I would appreciate any pointers else I'll likely give up and either get someone out or get a new one.
Ta in advance
Ta in advance
