My turn for an Adg957 fault. Machine is 18 years old, no Led display. In the past I've changed the NTC sensor
At the moment if I run it on any program, the pump runs and runs and after about 10 mins it starts to beep. The error code on the left most led (rinse) flashes twice a second so doesn't tie in with a specific fault.
I ran the diagnostic cycle (press and hold start while switching on till it flashes) the machine fills and runs, the water heats up ok, up to about 60c.
After the cycle (about 20 mins) the second from the left led is left flashing ( eco wash, next one along from rinse).
Everything I read just talks about the rinse led indicating a fault code.
Any clues?
Any clues?
