start flashes 4 times i know this means that it is a drain problem
if i place water in the bottom it does drain out so i know the plumbing is ok
any ideas
how do i reset the dishwasher
Reset is by holding the start button until the light goes out.
Remove the filter and mesh filter, inside the bowl you'll see a black grid, very carefully clean this out (an old toothbrush and boiling water is good) and try the machine again.
