Thanks in advance for the Help!
Problem first started as dishwasher stop during cycle and flashed 4 times
Error Code:
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect
Thanks to this forums help I tipped the dishwasher pull it apart, pump, sensor, took out the pressure switch diaphragm etc... put it all back together ran the daig ok. Dishwasher work twice then the 3rd time tripped the circuit breaker in the house. Water seem to be spilling into the bottom tray. I then took it apart again this time tested the pump on an external source no problems, even tested the temp sensor for fun.. all ok. Pressure switch diaphragm appeared ok. Put it back together and consistently get 6 flashes in diag mode
Error Code:
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
So logic tells me it's the Water Indicator (WI) as it is mentioned in both error codes?
Any ideas what part the water indicator is ? is it the pressure switch diaphragm that needs replacing?
Error Code:
Error Code:
