Whirlpool dishwasher ADP4504 problem
28 Jul 2007
Somerset
I have another problem with the above dishwasher. As before it is cleaned regularly and tries to work but fails to finish filling with water.
The error code is 7 flashes.
This is a recurring problems that usually clears after several attempts.
Can you help please.
Best regards
mpeter
Normally associated with a flow meter fault.
Remove the left hand side panel, locate the two wire plug at the bottom front of the water matrix. Pull the plug off, clean the connections and plug it on again.
Reset and try the machine again.
