Hi all, I inherited a Whirlpool ADG 8410 FD dishwasher which won't fill. It has been turned off for a long time, disconnected from water which I guess could have caused the problem. Now with the water turned on, selecting a program causes it to hum briefly, click rhythmically for about 10 seconds, then repeat this a few times until it beeps with the error code F4 E4 on its LED panel. No water enters the machine. If I chuck water in, after all this, it is pumped out.
I can't find a proper manual for this specific model - the "quick guide" only mentions other error codes. However, service manuals for other Whirlpool ADG dishwashers say F4 means a drain failure. That's weird because as I said it pumps out water fine.
So unless someone can advise what this error code means I'm wondering if this line with no proper manuals has some different meaning and it's actually an inlet failure. As far as I can tell, the optical water level switch is clear of crud (though the tub is *not* - there's quite a lot of crusty crud at the front edge) so presumably it's not that. I haven't been able to pull the machine out, and without a diagram for this unit I'm not really sure where anything is either. Any ideas for next steps?
