Whirlpool fridge freezer thermostat
25 Feb 2009
Sussex
Can anyone tell me how the thermostat is removed from a whirlpool fridge freezer? Mounted on the right in the fridge part, I can remove the knob and the nut from the stat spindle but the housing complete with the light stays firm and I cant see any other fixings. If the housing comes off am I likely to run into any other problems with the capillary? Thanks.
Most lamp/stat housings have one or two screws into the chassis to hold it in place (quite often under a cap or the lamp reflector)
Hi, there will be a hidden screw under the lamp or behind a removable section. Don't undo the nut on the spindle before you take the housing off. Also it may slide towards you and then out (on lugs)
