whirlpool solutin washer
25 Feb 2008
Leeds
when going on to spin making a loud noise as being un ballensed but allso when no washing in, move the controle switch and a loud grating noise and then it go`s quet looked at drum bearing near belt wheel looks ok but noise is coming from there do i have to put a new bearing in is it a inner and outer bearing and do i have to take the drum out to do this :mad:
If you attempt to lift the inner drum with your hand, is there ANY movement at all?
There should be none.
If there is any lift on the drum or if there is a grating/gringing noise when the drum is turned by hand your bearings are a gonner.
