found two stats at back of dryer when i test between the terminals should there be a low ohm reading on stat. also i have been reading about you can reset stats by pushing a button can't find a button to press on these two stats. tested across element this is ok
some stats you can reset by thowing them on the floor til the metal disc pops out ,link the stat out or 5 mins see if it works if ok you need a new stat,do not link out permantly.
no that is not the part, i have found the part i want but you have to buy the whole element because the 2 stats are attached to it. there must be somewhere i can just by the stat, please help
