Whirlpool washer only spinning for 3/4 seconds
10 Sep 2006
We have a AWM321 washing machine.
After the last few washes we've done the clothes have been very wet. When I checked the rinse cycle, it fires up for a fast spin, then after about 3 or 5 seconds it stops. The machine then rolls the washing over again for a few seconds before starting another spin for 3/5 seconds.
This continues throughout the rinse cycle.
What would cause this? :?:
Thanks breezer
I left the washing in and ran the gentle spin cycle. This worked OK.
I then removed the washing and ran intensive spin. This worked OK.
I then put the washing back in and ran intensive spin again. This worked OK.
Have you any thoughts on that!!?
i dont know your particular m/c but it my be what is called out of balance detection.
basicaly if a wash load is too heavy in one place the m/c when spinning will jump and shake quite violently. i have known a m/c to shake itself to to bits.
I also saw one that headbutted a little child
out of balance detection stops it from doin this.
on a hotpoint, it gets to near spin speed then slows down, stops and goes the other way trying to re distibute the load, if it fails after 3 goes it gives up
on the other hand i may be wrong
"I then put the washing back in and ran intensive spin again. This worked OK. "
What is currently the situation now if you put a normal load in now and run a programme does it not carry out the rinse/spin part of programme or does it not carry out the intensive part of the programme.
