whirlpool washing machine 8123/s leaking
7 Jul 2010
Hi
Need help fixing washing machine - water leaking from front right hand corner (underneath) on start of cycle - no leak when filling seems to start leaking after filling cycle ends - not a great amount and doesn't leak continously through cycle - just at the start
Have checked level and tilted machine slightly back. No sign of leak from drawer or door. Checked 'filter'? little round access door front bottom right of machine - full of water?
Not stripped top or back as not quite sure of what I am looking for - apart from water!!
Thanks in advance
Water leaks can be misleading as to where they come from as the water runs along ledges etc and can be from no where near where you see the water.
Common problems with leak only on fill are hole in door boot (water is soaked up by clothes etc after fill.
Water leaking from the dispenser drawer and running to the porthole and around it (normally looks like the door is leaking)
