Whisteling/screaching noise when boiler is firing
2 May 2006
Glasgow
All,
I'm hearing a noise when my boiler fires up. The noise is like a *mix* of car brakes screaching and a kettle boiling. Also there is a small leak from the underside of the bolier when its cold, this stops once its been running for a bit.
The noise lasts for longer when the bolier first fires up from cold.
Once up to 80' or so the noise is only there for 5-10 seconds when the flame first lights then it fades away, the flame and pump are left still running with no noise.
The noise is does not happen 100% of the time when the flame is on.
The CH and HW work fine, no loss of performence etc. since before the noise started.
Boiler is a Saunier Duval Thema F about 7+ years old.
Any suggestions on what this could be?
TIA
e
should have said its a combi boiler and I live in Glasgow which i think is a "softish" water area.
after finding the FAQ's :) seems like this is a case of "ketteling"
but with the addition of the leek does this suggest the heat exchanger is also damaged?
