In last month, boiler has started whistling after using hot water. Run water, switch taps off, then get whistling while pump does its overrun. Gets quite loud but is unpredictable - sometimes whistles sometimes doesn't. Started happening after replaced dhw pressure differential valve diaphragm, but maybe that's coincidence.
Seem to remember posts a while back about o-rings in diverter valve - does that sound right?
If it is the o-rings, can anyone tell me where exactly they are and how to replace? Thanks
