White Knight Sensordry Tumble Dryer
26 Jun 2006
Essex
The tumble dryer wil not 'tumble' when there is more than one item in it, if there is only one then it works.
Looking at previous posts suggest it may be the capacitor, is that correct?
Is it easy to replace?
Thank you.
I would have thought a loose or worn belt was your first thing to check.
Yes it could well be the capacitor, I've fitted dozens and they are easy to change, usually 8uF and probable around £4-5. I also have to say that it could be the motor and as they are an induction type, the cost would be more than replacing the whole machine.
Hope that helps
