White stuff on brick wall
4 Apr 2010
Yorkshire
My neighbour has had a wall made in his garden last week and now patches of white flaky stuff is appearing and as I drive round my estate I can see the same on most walls.
I am looking to have a wall built soon and I do not want the same to happen.
Can any one tell me what it is and if so can it be prevented? Cheers
its teh salts from the brickwork and cement coming thgrough. its only temporary and will stop after a while. you cant stop it, some bricks do it more than others, just needs brushing off.
It is efflorescence season.
We all got it.
It will eventually go after about ten Spring seasons. :rolleyes: :LOL:
The white stuff on your bricks is called Efflorescence. Efflorescence is a white crystalline or powdery, often fluffy/fuzzy deposit on the surface of masonry materials like concrete, brick, clay tile, etc. It's caused by water seeping through the wall/floor/object. The water dissolves salts inside the object while moving through it, then evaporates leaving the salt on the surface.
It can be relatively easy to remove compared to some other stains. Often these salts are water soluble and, if outside, may disappear of their own accord with normal weathering. This is particularly true of "new-building bloom." The water soluble salts can be removed by dry brushing or with water and a stiff brush. Heavy accumulation or stubborn deposits of white efflorescence salts can usually be removed with a solution of muriatic acid and scrubbing (1 part acid to 12 parts water -- this is a real acid, follow precautions on the label). Wet the surface well before and after the solution is applied.
Less common salts, that change their chemical structure during efflorescence formation, require proprietary compounds to remove.
Hope this helps!
