Hi - I'm seeking some impartial opinion on whether a fault with my water softener has been caused by a faulty part or whether it has been caused by my plumbing system.
To cut a long story short, my house is 5 years old and has a pressurised water system with a Megaflo. My incoming water pressure is about 2.2 bar. Earlier this year, the plastic blend valve broke on my water softener causing a serious flood. The engineer replaced it and it happened again 3 months later.
There are 2 possibilities: The plastic part is not up to the job. Or my plumber should have fitted a shock arrester somewhere near the water softener. Either way it begs the question, why didn't it happen sooner?
My main concern is to prevent it happening again. What do you think is the most likely cause of the problem?
