Who needs ash?
24 Sep 2005
There are many dangers in flying...
Cathay Pacific A330 + Trent engines (engines similar to the BA 777 BA038 crash landing at LHR).
13th April - Emergency landing at Hong Kong International Airport...
Cathay Pacific said:
...Manager Maintenance Support at the airline’s Engineering Department emphasised that safety is always the airline’s number one priority. He said that after further investigation of the flight data from CX780 and having interviewed the crew, updated information had shown a clear picture of this aspect of the incident.
He said it had been determined that the number 2 (RH) engine was at idle power throughout the approach and landing at HKIA, and the Number 1(LH) engine was operating at 70 per cent of its maximum power, and frozen at that level.
Mr. Hui said: “This is a higher power setting than is required for a normal approach with a single operating engine. Consequently, this higher than normal power setting led to a higher than normal approach speed and incorrect flap configuration.
“The aircraft therefore touched down at approx 230 knots, as against a normal 135 knots at this aircraft’s operating weight.
“ However, the aircraft touched down on the correct position on the runway, but due to its high speed had to brake hard and use reverse thrust from the operating engine to bring the aircraft to a halt.
“The high speed and high energy braking led to very hot brakes, tyre deflation and the report from the FSD outside the aircraft that it had observed flames and smoke on the landing gear,”
he added.
Mr. Hui said details of what happened and what caused the engine malfunction are now the subject of CAD investigations. Cathay Pacific was co-operating closely with the investigation, along with Airbus and Rolls Royce, the engine supplier...
If nothing else, nice to know it could, at such high speed, land and stop with 309 + 13 passengers and crew aboard... In the dry anyway.
AFAIK The tyres are designed to deflate under high energy braking to avoid bursting (wheel plug fuses )...
I guess this news was partly lost in the Iceland H15 Euro-haze !
-0-
