Hello,
Never posted on this forum before, so please bear with me.
A problem occured with our central heating/hot water about a months ago. There was a loud noise coming from our airing cupboard, which sounded like whooshing coming up from the boiler downstairs. This gradually increased in volume until the pipes were shaking in the airing cupboard and there was a loud release of hot water/steam into the expansion tank in the attic.
My system details are:
Ideal Classic LX RS260 Boiler
Grundfos Selectric 15-60 pump
Honeywell motorised 2 port valve
Myson aerject de-aerator
Danfoss ravi thermostatic cylinder valve
Initially, I thought a blockage in the system might have caused this pumping over into the attic. I have had the system powerflushed, but this proved unsuccesful in solving the problem.
I also installed a brand new pump, but this was also unsuccesful in curing the problem.
Subsequent to this, I identified some pipework in the airing cupboard which had blockages in, so I cut out the pipework and did a like for like replacement. I no longer think a blockage in the airing cupboard pipework is the problem because I have checked all the pipes with magnets and there is no attraction, and water seems to be flowing freely through the system.
I have also removed and checked the Danfoss thermostatic cylinder valve, and tested the thermostatic sensor to ensure it is functional, it is working fine.
The boiler stat is set to 3, and the boiler is still producing boiling water and pumping over. I previously thought the boiler thermostat was functioning fine, because the boiler stat turned off the boiler when the stat was turned down, and fired the boiler when turned up.
But could the boiler thermostat still be faulty even though it turns the boiler on/off?
When the boiler stat is turned down to 2, the problem still occurs althought it takes longer to occur. With the stat turned to 3 last night it was running fine for 1.5 hours before the pumping over occurred again.
This problem only occurs when I require hot water only (i.e. the motorised valve is not providing water to the radiator circuit).
I thought I had diagnosed and cured the problem, but I am all out of ideas now and cannot think what the problem could be.
If anyone can help I would be most grateful.
